Script's avatar
Script
Xr500 - higher ping now than compared to my modem
  • I’ve tried setting to 70%, tried default settings. Ping is roughly 10 higher or so
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      What is the model of the modem/router? How have you set this up, with XR in the DMZ, modem/bridge mode? Are ALL devices connected to the XR? Are you using Always or Auto Enable for Congestion Control?
      • Script's avatar
        Script
        Bridge mode from rogers modem, Ethernet cord from modem to router (xr500), router to switch and all devices hardwired with cat 5e and above. Without the router ping is normal. I’ve tried always on with 70% on both sliders didn’t do anything. Tried without any settings just fresh and same results.
