tClancey's avatar
Jan 24, 2019
xr500 + sky router + double nat
PLEASE NOTE, XR500, not C7000.  I can't find xr500 in the list.
A friend asked if I could help setup his new router, he has no laptop or pc, he's only just got used to using and phone.  In the end we used the xbox to set it up anyway,,,  So, all the advise I could find said...  Just plug it in, it'll work.  And I have to be honest, it did.  I was quite surprised!  Routers have definitely edveloped over the last few years.
However, Sky ISP to Sky router (IE15 ir something) to XR500 to Xbox results in a double nat situation which is a terrible outcome for gaming, which is all he does.
There are many posts here and there about getting these routers working with sky, but I cant' find any double nat solutions.  Can you please advise?
Thanks.
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    Thanks.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      The above is great advice. Also you may need to use DHCP Option 61 for Sky in Internet Setup.
      • tClancey's avatar
        tClancey
        Tutor
        As far as I'm aware the ER115 doesn't have a bridge mode, or modem only mode, it just isn't there.
        Sky do not give out login details so he can't use another modem.  Why he's so keen to use sky I have no idea, I'd sooner spit in my own ear, but each to their own!
        So that leaves the 2nd option.  Which is perfectly possible for him to setup through his xbox.  But I'm a little confused, how does setting a DMZ ip address get arround the double nat?  Surely each box is still doing the same as it was??
