clodgek
Aug 26, 2020Aspirant
XR500 -start up - blinking power light right out of box?
Been an ASUS user for 15+ years. Current model AC3100. Upgraded my ISP to Gigablast. Decided to upgrade modem and router to go along with Gigablast. Bought a CM 1000V2 and a XR500. The XR 500 got here yesterday and I hooked it up. Downloaded the Nighthawk app to get setup. Right outta the box the XR 500 has the power light blinking of death. Tried to re boot.... reboot cycle power button.... 30/30/30 reset... still blinks and does nothing. Reading that it’s a “ corrupt file”....??? Kidding me? After being on the phone with an idiot that took an hour just to register it.... BYW tells me that the serial # is invalid.... transfer me to another idiot that..... never answered after 2 hours on hold. Ridiculous.
The XR 500 is the top of gaming routers all over the web but yet out of the box... file corrupted? Joke!
Plug my ASUS back in and within seconds.... up and running. All the years of running ASUS... never had to call customer service once. Now, Iam sure that the CM1000 modem that I just bought will take a poop too... so Iam sure that I will have to go back to Arris
Extremely disappointed and last night was 3-1/2 hours of my life that I cannot get back.
- Netduma-FraserNetDuma PartnerI would recommend reinstalling the latest firmware using the TFTP method. This will install the firmware prior to the boot process and so will bypass any issues if they are there. Then would suggest a factory reset so you get the freshest install possible.
Firmware: https://kb.netgear.com/000061157/XR500-Firmware-Version-2-3-2-56
TFTP: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP?_ga=2.66553254.942403167.1598454020-1006726379.1598388461- clodgekAspirant
LMFAO..... So I pay $249+ tax and now I have to DL and re-insert a program (update) into the highest rated gaming router on the web? Kidding me?
I have returned it and Iam currently waiting for the new one to arrive, should be tomorrow. iF THIS ONE DOES THE SAME THING.... COMPLETELY done with NETGEAR bs.
At this price point, being NETGEAR, highest rated gaming router, I should be able to pull it out of the box and get it rolling with-in a half hour. Not fix a router then pray it works.
All the ASUS routers I have ever had ...out of the box kicked ass. Including the AC3100 that I have right now getting 550mb DL & 55MB UP load on a first gen PS4.
- Netduma-FraserNetDuma PartnerAll I can do is provide support once you have the router, I've no idea why that happened and I've not seen it before. Fingers crossed the replacement works well.
