manitou58
Apr 13, 2021Aspirant
XR500 2.4GHz band drops off very quickly at distance
I recently purchased the XR500 (had a R7000 Nigthhawk prior) and notice that the 2.4GHz band's speed is horrible when I am about 40 feet from the router. I did not have that issue with my other Netgear routers. I am not using Smart Connect and the 5GHz band works as expected. I am at V2.3.2.114 firmware. Anyone else see this horrible performance on the 2.4GHz band? Unfortunately I have devices that have to use this band. Thanks.
> [...] the 2.4GHz band's speed is horrible when I am about 40 feet from
> the router. [...]Neighbors? Is the XR500 using the same channel in the 2.4GHz band as
the previous router was? Have you investigated/tried other channels?- manitou58Aspirant
Yes I have tried some other channels and so far getting the same I have tried 3 so far and working my was down the list. Using a WIFI analyzer but even with what appears to be unused bands still having the same issue.
- Netduma-FraserNetDuma PartnerSet the router antennae to look like this _ | | _ so two straight up, one either side pointing outwards and see if that improves it. Do you have any wireless or electrical devices in close proximity to the router?
what actual performance numbers are you getting?
