blackshirt40
Dec 17, 2019Guide
Xr500 5g band completely disappears
Is there a newer beta firmware I can try? Ever since the last stable firmware was pushed out I have had really inconsistent wifi issues with the bands dropping randomly or just really poor performance. Was never an issue before.
- Netduma-FraserNetDuma PartnerThere isn't unfortunately. Are you using Smart Connect? If you disable this does it work any better when manually connecting to 5GHz?
- already tried that doesnt seem to help
- Netduma-FraserNetDuma PartnerHave you changed anything in Advanced WiFi Settings at all? Could you try making a guest WiFi network and see if that performs any better please?
