Rogue8448
Jul 27, 2019Aspirant
XR500 Advanced Traffic Prioritization
Was trying to set up traffic prioritization for Rainbow Six Siege on this, So I go to advanced and add Port 6016 to the source port and destination port and its still not picking up the packets.
- Netduma-FraserNetDuma PartnerAre you playing this on PC? Do not change the source port just the destination. Leave the source port as the default range it gives you and it will work. If you're using console there is no need to add manual ports.
- Rogue8448Aspirant
Yes im playing on PC. And set it up like you said -
UDP - Source Port (1:65535) - Destination Port (6015:6015)
And its still not detecting any high priority traffic when im playing siege.
- Netduma-FraserNetDuma PartnerMake sure you add the uPlay ports as well, does it work then?
