r1cketier
Sep 12, 2021Follower
XR500 AND IINET
Hello,
I've just moved to a house with FTTP. I had the XR500 working at my previous address (HFC connection) and have tried with no luck to set it up at the new house.
I have enabled VLAN tag to 2, and entered PPPOE login settings and cannot get a connection. Is someone able to assist?
It asks to enable one of the LAN ports or wifi, which am i supposed to select? I've spoken with iinet and they have said it should be PPPOE not IPOE.
Thanks in advance,
Ricky
1 Reply
- Netduma-FraserNetDuma PartnerFor VLAN remove the rule you've made and edit the existing internet rule and change it to 2, see if that works. Also set PPPoE to always connect.
