bsilverthorn
Dec 12, 2018Apprentice
XR500 and PI Hole configuration
I am looking for a way to use dnsmasq with the XR500. Or some way to have the pi hole software be able to report back what machines are actually doing the dns lookups. In most routers I have an option of setting specific DNS servers for DHCP. I do not see this in Netduma, it appears to use the DNS servers set on WAN connection or Ineternet. The issue with setting the first DNS entry to the PI Hole here is that that reporting metrics just show the DNS requests coming from the router not the actual device making the request. I could go around and set DNS staticly, but if I have to do that ill just move DHCP to linux and stop using the XR500 for DNS.
In the below post metioned it was stated to do the following:
"Within you lan dhcp scope set the dns for Lan devices to the Lan ip for your pihole device. That will forward all requests from Lan hosts to the pihole."
Could someone elberate a little more. Currently here is how we are setup.
Router at 192.168.1.1
PI Hole add blocker at 192.168.1.4
DNS on "internet setup"
Prim DNS 192.168.1.4 AKA pihole
Sec DNS 208.67.222.123
thrid dns 208.67.220.123
This works sorta, but again it shows DNS requests coming from my netgear. Is there a way to have the XR500 send out 192.168.1.4 as a DNS server and note the lan IP?
I found the following the post, but embarrassing the reply, did not make sense to me:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Nighthawk-XR500-DNSMASQ/m-p/1555398
- Netduma-FraserNetDuma PartnerI'd give Netgear support a call and see if they can help you with this issue.
Hi there. I have PiHole setup with the XR500. I just have the router do the DNS as I didn't see a way either to have it send DNS servers other than the router. Just curious, do you want to have it setup so that you see which hosts are doing which requests? If so, I'd just manually set the DNS servers on your OS and just get the IP/Netmask/Gateway from the DHCP server.
- Biggus42Tutor
I've had the same issue - it is as if the XR500 "Use These DNS Servers" option doesn't work.
No matter what you put in there, it just pushes down the values it gathers from your ISP; you cannot override them.
Is this something that is in the channel to get fixed?
Thank you!
- Netduma-FraserNetDuma PartnerBiggus, what happens after you set the DNS and apply? When it reloads the page has it switched back to dynamic or is it still on 'Use these...' but doing a DNS test it shows the ISP DNS?
