bigc1955's avatar
bigc1955
XR500 and VLANs
I'm looking to get an XR500 and replace my pfSense box.  I have a VLAN set on the pfSense box for my IOT devices.  Will I be able to do the same type setup with the XR500?
Thanks.
1 Reply
  • You're able to enable VLAN by bridge group or by VLAN tag group so it should be possible to do that yes.
