engneerngDynamo's avatar
Apr 24, 2018
XR500 as wireless ethernet bridge
I want to setup my XR500 as a wireless ethernet bridge.
Why?  Becuase I have an XR500 and 4 devices that do not have WiFi adapters in a room that I can't run a wire.
I know I could use a cheaper router to do this, but I already have an XR500.
I don't need to use the wi-fi on my XR500, except to brigde to another router.
(If I could run a wire, I would use a 5 port Gb switch)
Netgear has instructions for how to set up a router in bridge mode:
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
But I think these instructions are not for the XR500.
Any help is appreciated.
    • Danny80916's avatar
      Danny80916
      Luminary
      I have that same extender its , amazing piece of hardware so many options for it .
    • JasonN's avatar
      JasonN
      NETGEAR Employee Retired
      Hi engineeringDynamo,
      Thank you for updating the thread. I'm glad you have found a workaround.
      Please let us know if you have any other questions. :]
      - Jason N
  • JasonN's avatar
    JasonN
    That KB instructions is not for the XR500. You can see on the right of the page that it lists all the devices that those instructions go to.
    - Jason N
  • As far as I know this isn't possible with the XR500. We didn't create the Settings though so maybe worth giving Netgear a call to double check.
