anovelli2002
Oct 29, 2021Aspirant
XR500 beta
i recently installed the beta version for the xr500. it is still losing wifi fir a min at a time. I am definetely unhappy with the amount spent for the wifi to be going out as often as it has been. Any help would be great
- Netduma-FraserNetDuma PartnerWhat happens exactly, your wireless device loses internet and it gets restored a minute later? If so can you provide the log file from the System Information page around the time this happens please?
- anovelli2002Aspirant
i wasnt able to get the log in time before it was gone. The unit just diconnected to the computer and when I went to look it had the left two led orange. I had to power off unit for it to connect again. It happened twice in 20 min.
here is the log from today if that helps
[DumaOS] Theme path does match manifest 'default', Saturday, October 30, 2021 14:38:51
[DumaOS] The selected theme does not exist: 'default', Saturday, October 30, 2021 14:38:51
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Saturday, October 30, 2021 14:44:47
[DHCP IP: 192.168.1.7] to MAC address 5a:15:94:13:ec:a0, Saturday, October 30, 2021 14:48:52
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:48:52
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:48:52
[DHCP IP: 192.168.1.49] to MAC address 2e:63:c5:69:da:97, Saturday, October 30, 2021 14:48:55
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:48:55
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:48:55
[DHCP IP: 192.168.1.39] to MAC address f2:31:e3:a5:e4:29, Saturday, October 30, 2021 14:49:04
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:49:04
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:49:04
[DHCP IP: 192.168.1.7] to MAC address 5a:15:94:13:ec:a0, Saturday, October 30, 2021 14:49:57
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:49:57
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:49:57
[DHCP IP: 192.168.1.49] to MAC address 2e:63:c5:69:da:97, Saturday, October 30, 2021 14:49:58
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:49:58
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:49:58
[DHCP IP: 192.168.1.4] to MAC address 00:7c:2d:78:88:58, Saturday, October 30, 2021 14:52:51
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:52:51
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:52:51
[DHCP IP: 192.168.1.4] to MAC address 00:7c:2d:78:88:58, Saturday, October 30, 2021 14:52:53
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:52:53
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:52:53
[DHCP IP: 192.168.1.37] to MAC address b8:31:b5:48:86:97, Saturday, October 30, 2021 14:53:07
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:53:07
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:53:07
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Saturday, October 30, 2021 14:53:08
[UPnP set event: add_nat_rule] from source 192.168.1.37, Saturday, October 30, 2021 14:53:10
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Saturday, October 30, 2021 14:53:11
[DHCP IP: 192.168.1.28] to MAC address ac:ae:19:aa:65:58, Saturday, October 30, 2021 14:53:48
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:53:48
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:53:48
[DHCP IP: 192.168.1.37] to MAC address b8:31:b5:48:86:97, Saturday, October 30, 2021 14:55:36
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:55:37
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:55:37
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Saturday, October 30, 2021 14:55:40
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Saturday, October 30, 2021 14:55:42
[UPnP set event: del_nat_rule] from source 192.168.1.37, Saturday, October 30, 2021 14:55:46
[UPnP set event: add_nat_rule] from source 192.168.1.37, Saturday, October 30, 2021 14:55:46
[DHCP IP: 192.168.1.41] to MAC address 28:16:ad:b0:8a:74, Saturday, October 30, 2021 14:56:13
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:56:13
[DumaOS] DHCP new lease allocated., Saturday, October 30, 2021 14:56:13
[DHCP IP: 192.168.1.7] to MAC address 5a:15:94:13:ec:a0, Saturday, October 30, 2021 14:57:14
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:57:14
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:57:14
[DHCP IP: 192.168.1.5] to MAC address 56:12:c8:f8:4b:5e, Saturday, October 30, 2021 14:57:20
[DumaOS] DHCP new event., Saturday, October 30, 2021 14:57:20
[DumaOS] DHCP lease change., Saturday, October 30, 2021 14:57:20
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:44
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:45
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:46
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:47
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:48
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:49
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:50
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:51
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:52
[DoS Attack: ACK Scan] from source: 40.83.240.146, port 443, Saturday, October 30, 2021 15:00:53
[DHCP IP: 192.168.1.19] to MAC address 5e:56:e1:92:f8:d8, Saturday, October 30, 2021 15:02:04
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:02:04
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:02:04
[UPnP set event: del_nat_rule] from source 192.168.1.37, Saturday, October 30, 2021 15:05:37
[DHCP IP: 192.168.1.5] to MAC address 56:12:c8:f8:4b:5e, Saturday, October 30, 2021 15:05:47
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:05:47
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:05:47
[DHCP IP: 192.168.1.4] to MAC address 00:7c:2d:78:88:58, Saturday, October 30, 2021 15:07:20
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:07:20
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:07:20
[DHCP IP: 192.168.1.4] to MAC address 00:7c:2d:78:88:58, Saturday, October 30, 2021 15:07:21
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:07:21
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:07:21
[DHCP IP: 192.168.1.39] to MAC address f2:31:e3:a5:e4:29, Saturday, October 30, 2021 15:08:49
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:08:50
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:08:50
[DHCP IP: 192.168.1.28] to MAC address ac:ae:19:aa:65:58, Saturday, October 30, 2021 15:09:01
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:09:01
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:09:01
[DoS Attack: SYN/ACK Scan] from source: 104.87.0.22, port 443, Saturday, October 30, 2021 15:11:44
[DHCP IP: 192.168.1.5] to MAC address 56:12:c8:f8:4b:5e, Saturday, October 30, 2021 15:12:01
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:12:01
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:12:01
[DHCP IP: 192.168.1.5] to MAC address 56:12:c8:f8:4b:5e, Saturday, October 30, 2021 15:12:09
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:12:09
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:12:09
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:16:41
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:16:42
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:16:44
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:16:48
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:16:56
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:17:13
[DHCP IP: 192.168.1.10] to MAC address 1c:9e:46:da:d6:6b, Saturday, October 30, 2021 15:24:48
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:24:48
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:24:48
[DHCP IP: 192.168.1.41] to MAC address 28:16:ad:b0:8a:74, Saturday, October 30, 2021 15:26:44
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:26:44
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:26:44
[DHCP IP: 192.168.1.41] to MAC address 28:16:ad:b0:8a:74, Saturday, October 30, 2021 15:41:27
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:41:27
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:41:27
[DHCP IP: 192.168.1.18] to MAC address 34:7e:5c:c2:4c:c4, Saturday, October 30, 2021 15:41:51
[DumaOS] DHCP new event., Saturday, October 30, 2021 15:41:51
[DumaOS] DHCP lease change., Saturday, October 30, 2021 15:41:51
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:45:52
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:45:53
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:45:55
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 15:45:59
[DoS Attack: SYN/ACK Scan] from source: 54.38.18.213, port 25416, Saturday, October 30, 2021 15:54:29
[DoS Attack: SYN/ACK Scan] from source: 168.119.232.76, port 443, Saturday, October 30, 2021 15:54:39
[DoS Attack: SYN/ACK Scan] from source: 54.38.18.213, port 25416, Saturday, October 30, 2021 15:55:01
[DHCP IP: 192.168.1.41] to MAC address 28:16:ad:b0:8a:74, Saturday, October 30, 2021 16:03:31
[DumaOS] DHCP new event., Saturday, October 30, 2021 16:03:31
[DumaOS] DHCP lease change., Saturday, October 30, 2021 16:03:31
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.125, port 123, Saturday, October 30, 2021 16:15:19
[DoS Attack: SYN/ACK Scan] from source: 198.251.89.41, port 25565, Saturday, October 30, 2021 16:28:24
[DoS Attack: SYN/ACK Scan] from source: 198.251.89.41, port 25565, Saturday, October 30, 2021 16:28:25
[DoS Attack: SYN/ACK Scan] from source: 198.251.89.41, port 25565, Saturday, October 30, 2021 16:28:27
[DoS Attack: TCP/UDP Echo] from source: 17.253.20.253, port 123, Saturday, October 30, 2021 16:31:55
[DoS Attack: TCP/UDP Echo] from source: 17.253.20.125, port 123, Saturday, October 30, 2021 16:31:57
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.125, port 123, Saturday, October 30, 2021 16:31:59
[DoS Attack: SYN/ACK Scan] from source: 104.87.0.22, port 443, Saturday, October 30, 2021 16:45:05
[DHCP IP: 192.168.1.36] to MAC address ac:ae:19:aa:6e:bc, Saturday, October 30, 2021 16:53:19
[DumaOS] DHCP new event., Saturday, October 30, 2021 16:53:19
[DumaOS] DHCP lease change., Saturday, October 30, 2021 16:53:19
[DHCP IP: 192.168.1.41] to MAC address 28:16:ad:b0:8a:74, Saturday, October 30, 2021 16:54:32
[DumaOS] DHCP new event., Saturday, October 30, 2021 16:54:32
[DumaOS] DHCP lease change., Saturday, October 30, 2021 16:54:32
[DoS Attack: TCP/UDP Echo] from source: 17.253.24.253, port 123, Saturday, October 30, 2021 16:57:25
[DoS Attack: TCP/UDP Echo] from source: 17.253.20.125, port 123, Saturday, October 30, 2021 16:57:27
[DoS Attack: SYN/ACK Scan] from source: 144.76.195.84, port 80, Saturday, October 30, 2021 17:02:30
[DoS Attack: SYN/ACK Scan] from source: 51.195.146.42, port 22, Saturday, October 30, 2021 17:02:34
[DHCP IP: 192.168.1.31] to MAC address 9a:31:81:1f:7e:33, Saturday, October 30, 2021 17:10:56
[DumaOS] DHCP new event., Saturday, October 30, 2021 17:10:56
[DumaOS] DHCP lease change., Saturday, October 30, 2021 17:10:56
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 17:12:33
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 17:12:34
[DoS Attack: SYN/ACK Scan] from source: 172.217.194.153, port 443, Saturday, October 30, 2021 17:12:36
[DoS Attack: ACK Scan] from source: 195.140.202.142, port 6668, Saturday, October 30, 2021 17:14:58
[DHCP IP: 192.168.1.35] to MAC address 30:24:32:ec:26:0b, Saturday, October 30, 2021 17:20:53
[DumaOS] DHCP new event., Saturday, October 30, 2021 17:20:53
[DumaOS] DHCP lease change., Saturday, October 30, 2021 17:20:53
[admin login] from source 192.168.1.35, Saturday, October 30, 2021 17:22:12
[DumaOS] config write 'com.netdumsoftware.geofilter.settings', Saturday, October 30, 2021 17:22:17
[DHCP IP: 192.168.1.35] to MAC address 30:24:32:ec:26:0b, Saturday, October 30, 2021 17:23:55
[DumaOS] DHCP new event., Saturday, October 30, 2021 17:23:55
[DumaOS] DHCP lease change., Saturday, October 30, 2021 17:23:55
[DHCP IP: 192.168.1.35] to MAC address 30:24:32:ec:26:0b, Saturday, October 30, 2021 17:26:57
[DumaOS] DHCP new event., Saturday, October 30, 2021 17:26:57
[DumaOS] DHCP lease change., Saturday, October 30, 2021 17:26:57- Netduma-FraserNetDuma PartnerAre you using Smart Connect for WiFi? In LAN Settings, change the DHCP range to start at .50 instead of .2 then give devices reserved IPs between .2 and .49 and see if you notice a difference please.
Factory reset the router and setup from scratch.
Change the LAN IP address pool range to 192.168.1.100 to .200. Apply the change and the router should reboot itself.
For beta FW and experiences be sure to post over tin the beta forum for the XR series:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
