Spoidah's avatar
Spoidah
Follower
Dec 08, 2019
XR500 can't access settings in chrome
For whatever reason, I'm experiencing the same issues experienced in https://forum.netduma.com/topic/28787-settings-not-appearing/
Basically, using chrome to go to routerlogin.net ends up sometimes coming up with null error messages, and when I click 'settings' it comes up with the old netgear 'basic/advanced' interface, and doesn't load properly, everything stays blank except for a few tabs and logos that I can't click on (pic related). If I type 192.168.1.1 into the url instead, the website loads up properly, and I can access settings again.
This problem doesn't appear in any other browsers, just chrome. It just recently started happening in the last month or so, I think it was the new firmware update.
This problem is persistent across multiple devices, and I have factory reset the router multiple times (and uninstalled + reinstalled chrome + flushed cache on each device).
  • FURRYe38's avatar
    Do FireFox or Opera access these settings?
    Clear all browser caches before entering into the routers web page.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Do you have any Anti-Virus/Firewall applications at all? We've seen it in the past where this can affect the interface. If so try to add exceptions to them for the interface URL - routerlogin.net* the reason it may not do this when using the IP is it may not recognise it as a website. Also do you have any extensions on the browser? Ad block can sometimes cause the issue as well.
