jebrown1979
Dec 17, 2019Guide
xr500 can't login to duma os
so i can't login to netgear duma os . keeps saying duma os not loaded yet . factory reset my router and cleared all browsing data. so contacted netgear who told me to phone them, then insited i pay £...
Netduma-Fraser
Dec 17, 2019NetDuma Partner
We have received multiple reports about these issues. I have reported this to our team as this seems to be affecting a few people today, please follow these instructions provided as a workaround while we investigate. Please try a factory reset first before trying this workaround using the button at the back of the router and holding it down for 30 seconds then allowing 1-2 minutes for boot up before accessing:
1. Go to http://routerlogin.net/adv_index.htm
2. Administration -> Firmware Update
3. Download this firmware (two versions below .56*) http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip
4. Unpack the .zip file
5. Browse to Image file
6. Upload
7. Go back to Administration -> Firmware Update and disable Auto Upgrade until we can say this has been resolved.
*This versions lack some security updates but this is unlikely to affect you as well as some features (e.g. Ping Assist & Device Manager Table View) from the .56 firmware
6. Upload
- Netduma-FraserDec 17, 2019NetDuma PartnerWe have now fixed the issue, please see here for the fix: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Fix-for-quot-DumaOS-not-loaded-yet-quot-XR500-users-only/m-p/1838160#M15459
