Danmc17's avatar
Danmc17
Tutor
Oct 15, 2019
Xr500 connected to BT Smarthub settings.
Good morning,
I have an xr500 which up until this week I thought was running without issue but currently I'm having ps4 party chat issues. I just put my lan back into the back of my Smarthub and even though my call of duty connection went from Open to moderate this fixed the party chat issue I was having.
Does anyone have any optimal settings for connecting the xr500 to the Bt Smarthub primarily for call of duty purposes.
Thanks.
  • plemans's avatar
    If you were able to plug into the back of the smart hub and it worked plus you have the XR500 running, are they both running in router mode? If so you're probably in a double nat which can cause issues.
    https://kb.netgear.com/30186/What-is-Double-NAT
    You could try putting your xr500 in access point mode (you lost some of the features of the xr500) and seeing if it fixes the issues. Probably the fastest fix to the problem. Otherwise you'd need to put your bt smarthub into passthrough/gateway only mode.  If you desire to do that, I'd contact your isp for setting passthrough up successfully.
    • Danmc17's avatar
      Danmc17
      Tutor
      I have the WiFi disabled on the Smarthub and placed it into a dmz on its own software. As far as I'm aware the Smarthub can't be run in bridge mode.
      Seemed absolutely fine up until this week. (been running for about a month)
      • plemans's avatar
        if you're able to have your router and your ps4 hooked to it, its still running some router functions and could be causing the issue.
        For some, a double nat doesn't cause any issues or very minor issues. Others have all kinds of problems like apps not update to even not able to connect at all.
        An easy test is to use the smarthub as router (with just wifi disabled) and the xr500 as an access point. If it works fine, then its an issue with the smarthub and how its handling its routing function.
