jonnysbazar's avatar
jonnysbazar
Xr500 Constantly rebooting !
Guys Just came here from the topc I read one costumer had the same problem that I am having! I opened a ticket and someone here fixed the rebooting problem for Xr500?
Every 15 min it stops and start again.. very annoying but I am love this MODEM!
Anyway.. if someone has the same problem..
I got it on costco in  2018 and I did the extened warranty! Thanks God!
let me know if you guys having the same problem and how to fix it! Thank you!
Dhyogo Azevedo|!
1 Reply
  • First I would suggest plugging directly into a wall outlet to rule out any issues with a power extender. If it still occurs try using a different power adapter with the same voltage to see if that is faulty. If it still occurs then I would recommend you get the router replaced.
