Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
DrunkMonk74
May 17, 2018Star
Can confirm this is happening ALOT on my XR500. Constantly dropping the internet, all devices connected, (either wired or wireless) will lose internet connection. Reboot and it stays stable for a while, but problem re-occurs and starts to re-occur more frequently. It's not just while gaming either. Just while I was typing this I lost internet and it came back.
I'm on PC, but like I said it doesn't matter what device(s) you are using.
Netduma-Fraser
May 17, 2018NetDuma Partner
We're narrowing down on the issue. Do you use an Xbox One by any chance?
- DrunkMonk74May 17, 2018Star
No mate, don't have an Xbox One. I do have Windows 10, 1803, but I have removed all Xbox apps from there, GAME DVR is disabled, etc. Also my wife has been using her work laptop to work from home all day, and they definitely don't have any Xbox apps on there and it's been terrible for her.
So far I have set anti-buffer bloat to NEVER = random disconnects
Disable Port Scan and DoS Protection (enabled) = random disconnects
I've now turned off QoS totally and am testing that. If that fails then I will turn off UPnP.
Basically trying to go through things one by one to see if I can locate what is causing this. But obviously turning off some of these settings isn't ideal as you are disabling features that are the very reason for you purchasing the router.
- Netduma-FraserMay 17, 2018NetDuma PartnerThanks for the additional information, I have also sent you a PM with something to try.
- Billybudz420May 17, 2018ApprenticeI have been having another issue. Any Android device wouldn't work on wifi with this router.The play store and you tube would work. I have Comcast internet and it's their dns causing problems.I added the DNS servers manually and added Google DNS for the 3 DNS server works great now. Kinda strange why Comcast DNS would work right....the other issues are still on going.I play call of duty,mortal Kombat, battlefield,and my daughter plays Roblox which doesn't work unless I change the Geo filter settings same if I play any other game....this is a major pain in the behind every time I play a different game
- CajunbullNov 13, 2018Aspirant
Im having the same issue.New router bought Sat 11-10 I do have 2 Xboxes connected. 1 hardwired and the other wireless. I have to power cycle router everyday to get conection back. I have the current firmware any sugestions? have a NG 6400 no issues at all.
- HateNov 13, 2018Apprentice
Unfortunately, they can't be bothered to release a fix. I am sorry this is happening to you, it is absolutely ridiculous.
It's been nothing by lip service by both parties and they still haven't even bothered to acknowledge it, they truly think there aren't any issues with .32, rather comical.
Try downgrading to .22, reset to defaults, then give the Xboxs a Static IP on the router itself. Apparently "Instant On" causes issues.
So what whold be a "Good reliable option"?
- FURRYe38Nov 13, 2018Guru - Experienced User
Try a factory reset. Seems to help others.
Not everyone is having bad experiences. There are many factors that can contribute to routers not working. It's not always the routers fault.
- GingegNov 13, 2018GuideAs well as doing a factory reset you could try reinstalling the latest firmware again. Then try a reset to factory settings again and setup the router. I have done this before For people who have had connection problems with their routers and it has fixed their problem. Maybe worth a shot.
