Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Nov 13, 2018Guru
Try a factory reset. Seems to help others.
Not everyone is having bad experiences. There are many factors that can contribute to routers not working. It's not always the routers fault.
Cajunbull wrote:
Im having the same issue.New router bought Sat 11-10 I do have 2 Xboxes connected. 1 hardwired and the other wireless. I have to power cycle router everyday to get conection back. I have the current firmware any sugestions? have a NG 6400 no issues at all.
Gingeg
Nov 14, 2018Guide
As well as doing a factory reset you could try reinstalling the latest firmware again. Then try a reset to factory settings again and setup the router. I have done this before For people who have had connection problems with their routers and it has fixed their problem. Maybe worth a shot.
- Netduma_JackNov 14, 2018NetDuma Partner
That's a good suggestion. Sometimes reinstalling the firmware can solve weird cases.
