Deijeneiro's avatar
Aug 12, 2020
XR500 Dumo OS 3.0 beta
Hi , I would like to know if I’m succesfully registered for the beta? Since its been like two months ago and people already recieved emails. Username should either be Deijeneiro or Marvin. This is takin’ very long tbh.
  • If the form submitted successfully then you'll be signed up. All you need to do is wait for an email invite. I think more users will be invited one the next beta build is available.
    • D3vious's avatar
      D3vious
      Star
      I would love the link too!
      Does the beta address the QOS not working as designed when connected via a vlan?
      Cheers!
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        mc1500mc You don't appear on the Geo-Filter yourself so that will be someone you're connected to. You're likely showing the server and a player at the same time. If there is still a connection it will appear but then disappear shortly afterwards. Device manager fixes are coming in next build. That error is because you have probably rebooted and the name of the device changed or was removed. If you add the device back with the same name or reset it will be fixed. Also please post errors on the beta build to the beta section that I gave you the link to on the Netduma forum.
  • Netduma-Fraser
    i am noticing as i am playing Modern Warfare on PS4 multiplayer, that my servers are not where they should be. As i was the host of the room i showed my icon to be 100's of miles away from my location.
    I am also noticing that i am connected to more than one server at a time which is not the case.
    It appears there are Ghost Servers being shown. I have attempted to blacklist these without success.
    There are also servers showing up when i am not actively playing. (attached screenshot)
    I also notice that when i shut a device down on my network that the Device manager still shows it online, even 24hrs later after the device was powered off. the fix so far has been to reboot the router.
    • mc1500mc's avatar
      mc1500mc
      mc1500mc wrote:
      Netduma-Fraser
      Netduma-Fraser Here is another issue im having. whe Geofilter starts to load i get an error message and the app never loads. see attached file.
