Ethanxd9
Feb 04, 2023Aspirant
xr500 ethernet disconnecting after a few games on xbox s
hi im new to the netgear stuff and ive got the xr500 i set it up optimized geofilter and qos and got to playing played a few games and i lag out i go look at the xr500 and its blinking amber lights o...
- Feb 08, 2023
OK, so does it seem as though the XR500 is rebooting itself, causing you to lose connection to your game?
Could you please try going to Settings -> Setup -> LAN Setup. Here, please change the minimum DHCP value to 100. Then, resercve an IP address for each device on the network. Give each device an IP address between .2 and .99.
See if you're still having problems after that.
Feb 05, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Ethanxd9
Feb 08, 2023Aspirant
It’s currently 2.3.2.134 , it’s a technicolor cgm4141 from cox and yes it’s a cat6 Ethernet cord and yes I’ve done all the stuff you have listed since the last fw update .
- Netduma-LiamFeb 08, 2023NetDuma Partner
- Ethanxd9Feb 09, 2023AspirantYes this is exactly what it’s doing but I am not seeing dhcp value when I go to lab setup
- Netduma-LiamFeb 10, 2023NetDuma Partner
It may be called 'Starting IP address' or something along these lines. The most important step is to reserve IP addresses for each device, so make sure you've done this.
- FURRYe38Feb 08, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
Ethanxd9 wrote:
It’s currently 2.3.2.134 , it’s a technicolor cgm4141 from cox and yes it’s a cat6 Ethernet cord and yes I’ve done all the stuff you have listed since the last fw update .- Ethanxd9Feb 09, 2023AspirantI enabled bridge mode on my modem because I don’t quite understand the DMZ and it’s still having the same problems like it’s rebooting it self after a few games
