Ethanxd9
Feb 04, 2023Aspirant
xr500 ethernet disconnecting after a few games on xbox s
hi im new to the netgear stuff and ive got the xr500 i set it up optimized geofilter and qos and got to playing played a few games and i lag out i go look at the xr500 and its blinking amber lights o...
- Feb 08, 2023
OK, so does it seem as though the XR500 is rebooting itself, causing you to lose connection to your game?
Could you please try going to Settings -> Setup -> LAN Setup. Here, please change the minimum DHCP value to 100. Then, resercve an IP address for each device on the network. Give each device an IP address between .2 and .99.
See if you're still having problems after that.
Ethanxd9
Feb 13, 2023Aspirant
that worked thanks very much is there anyway you can tell me why most of the servers for mw2 my ping heatmap fails to ping there in my geofilter radius but it fails to ping them at all
Netduma-Liam
Feb 13, 2023NetDuma Partner
They change their server information frequently, so we just need to update them. The team are working on that now so you should see those servers back and responding later today.
- FURRYe38Feb 13, 2023Guru - Experienced User
