Laryke
Oct 29, 2021Apprentice
XR500 fiber
What will be the best settings for a fiber connection.
Also when I do a test on dslreports, I got C grade on bufferbloat and upload speed is always 940+ even I have qos set to “Always” and upload to 25%
My speed:940up and down
- Netduma-FraserNetDuma PartnerBufferbloat only occurs when the connection is saturated and at your speeds that is quite hard to do. I would recommend you try different percentages and find what feels best to you when gaming - every connection is different so it's hard to give a definitive value but we usually recommend 70% as a starting point
- LarykeApprenticeBut feels like for upload even if I put Qos at 25% and always, I still get full speed
- Netduma-FraserNetDuma PartnerWhat is the modem model the XR is connected to? Are you using PPPoE, VLAN or IPv6 on the XR?
