Bergli's avatar
Bergli
Follower
Jan 10, 2021
XR500 fluctuation
Why does the send, recive and the tick rate fluctuate so much?
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
  • It is dependent on the game, it's nothing you can influence on your side. If you feel it fluctuates too much and that is affecting your gameplay then I would suggest forcing a different server.
