catalano's avatar
Mar 19, 2020
Xr500 help
Hello,
i have put my Rogers cable modem/router combo (CGM4140COM) (Technicolor) in bridge mode and i have connected my xr500. I have been noticing that with my xr500 i am getting higher pings. I have read that i will need to get my old router MAC and change my xr500 MAC to my old router MAC. i have went into my rogers network settings and noticed 3 types of MAC. WAN MAC / eMTA MAC / CM MAC. i am not sure which MAC would be my old router MAC. my modem from my ISP is a modem/router combo (CABLE). How would i find out my old router MAC on my modem/router combo and would i have to take my modem/router combo out of bridge mode and unhook my xr500 to find out my old router MAC?
Also my xb6 modem/router from my isp does my home phone, tv and internet all in one. My bridge mode is enabled while connected to my xr500.
Thank you
  • Have you just purchased the XR500? If not then the MAC address suggestion you've mentioned won't make a difference. Take the XB6 out of bridge mode and instead put the XR500 WAN IP (found in System Information) into the DMZ on the XB6 and that should perform better. If possible disable the WiFi on the XB6 also so the XR can control all devices properly, otherwise it won't be able to eliminate local congestion effectively.
    • catalano's avatar
      catalano
      Tutor
      Yes I have just purchased the xr500 3 days ago. Okay so I should do what you have said then and don’t configure my XB6 on bridge mode. I will try that out and get back to you shorty. Thank you!
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Yes please do that and if that doesn't help we can go with the MAC method to see if it helps.
