fedupofmyXR500
Oct 26, 2022Aspirant
XR500 how to schedule a daily reboot or a DHCP renewal ?
Hello,
My XR500 looses my ISP gateway, DNS and DHCP server almost every 24 hours. The result is a loss of internet connection.
I have two ways to reconnect :
1) in DumasOS menu, i go to Settings>Monitoring>Connection Status and click on Renew
2) Reboot the XR500
Is there a way to automate one of these tasks by a scheduled command line ?
Thanks for your answers.
best regards.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
- fedupofmyXR500Aspirant
Hello,
Thanks for your answer. I appreciate your help but I’m not trying to debug the problem anymore. I already spent so many days and nights trying to solve all the XR500’s bugs (wifi not accessing local lan, dhcp lease changes, internet disconnection). I read all the posts regarding these problems, I already applied dhcp range, firwmare downgrade, hardware reset, firmware upgrade, praied for god’s sake and tried to put a voodoo spell on my router just to make it do the job it is designed for 😉
Finally, I gave up and I’m just looking for a workaround. A daily reboot solves the problem so i want to go for it if it is technically possible.- Netduma-LiamNetDuma Partner
There isn't anything available in the software to schedule a reboot every so often.
The solution to this problem for most people is to change the DHCP pool as mentioned, then reserve an IP address for every device in the network. After that, you shouldn't be experiencing the problem anymore.
