Rjaaayyy
Aug 31, 2022Aspirant
xr500 internet drops
hi im on latest firmware, tried most of the solutions and my internet drops few times a day. Weird part is, i cant access the log while its off internet no matter what i try. I have tried static IP, tweaking IP and DNS. Aswell as other solutions, anybody have a fix to limit the amount of times this happens per day?
- Netduma-LiamNetDuma Partner
Hey, this forum is monitored and supported similarly to the Netduma forum. I know I mentioned over there that you could try reaching out to NETGEAR support, apologies for any confusion there. I was referring to opening a ticket at support.netgear.com, rather than this support forum.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the DHCP IP address pool range set for?
- RjaaayyyAspirantCat6 is the cable I’m using. Modem is a Shaw one in bridge mode. I think the starting IP is 2 and ending is 254. Use router as dhcp server is checkmarked.
- Netduma-FraserNetDuma PartnerDoes the internet restore itself or do you need to reboot/factory reset to gain internet/access?
