ArnaudM's avatar
ArnaudM
Tutor
Apr 16, 2018
XR500 internet time setup and SSH access
Hi experts. Couple of questions for you. I recently bought the XR500 as I got seduced by the DumaOS screens. I previsouly had a Netgear R7000 which I had flashed with DD-WRT Kongo. Liked it a lot but to be honnest the idea of having fancy bandwidth graphs pushed me to the XR500. While the interface is really neat, there are number of features I miss from DD-WRT, and some other upgrades I am hoping for (more icons for the devices e.g. switches, the ability to disconnect a device from the network as the blocking feature works only if the device tries to connect...). I am running version V2.2.1.10 which I believe is the latest one.
To the questions:
- I must be a little tired or something... how do we change the timezone ? Programming the wifi ON/OFF on specific hours would be much easier if the router was set on my timezone...
- is SSH connection blocked ? putty tells me "connection refused"?
- I seem to be able to access the interface thru HTTP or HTTPS... how do I limit to HTTPS?
thanks much!
Arnaud
  • Do let us know your suggestions, we love customer feedback!
    - Settings > Content Filtering > Schedule.
    - Yes it is blocked
    - I don't believe there is a way to limit it to HTTPS.
    • ArnaudM's avatar
      ArnaudM
      Tutor
      Thanks! Sorry for missing the way to set the router time, to be honest I was not expecting this one under Content Filtering (would rather see this in Setup or Advanced Settings maybe?).
      Limiting to HTTPS would be a neat feature for a next release (only allow TCP:443 e.g.) as well as SSH. If I were to ask for features, I would suggest allowing the user to upload additional device pictures (like PNG format, certain size etc) to represent more devices (or get them from the community), the ability to import/export list of static IP's or static routes, access to cron, ability to poll SNMP (an advanced Traffic Meter) and uploading to a Syslog server. These are good features from DD-WRT I've been using a lot :)
      Thanks again !
      • JasonN's avatar
        JasonN
        NETGEAR Employee Retired
        Hi ArnaudM,
        Thank you for your suggestions. I will be forwarding these ideas to my internal team to review for consideration. :]
        - Jason N
