Jake1400
Sep 03, 2020Aspirant
xr500 issues
Hello, I recently bought the xr500 and have been having some issues with NAT and wired connection. When I first set it up and tried playing xbox, I was given the double NAT. I fixed this by switching the router to AP mode but I was wondering if there was a way I could remove double NAT without AP mode because this takes away all the features of the router. Another issue I have is that I can’t use a wired connection on my Xbox with this router as it gives me a “NAT unavailable”. How do I fix this?
- Netduma-FraserNetDuma PartnerWhat is your exact physical setup? Setting NAT to Open in WAN settings will help with this as well.
- Jake1400AspirantI have a modem that the router is plugged into. Then I have the Netgear PL1000 plugged into an outlet and into the router. My other PL1000 is plugged into an outlet near my Xbox and I have an Ethernet core running from that to the xbox. And how do I set the NAT to open in WAN settings?
- Netduma-FraserNetDuma PartnerWhat is the modem model? Go to Settings > WAN Setup and you can change it there.
