aeroluis88
Jun 16, 2020Aspirant
XR500 Ivacy Setup
Hi guys!
I kindly request your support if there is any of you using Ivacy VPN could guide me on how to connect as VPN Hybrid.
Regards
aeroluis88Exact instcution:
Hi, seems that mod only can give guides :-)
1. download and unpack: https://ivacy.s3.amazonaws.com/support/OpenVPN-Configs.rar
2. choose any .ovpn file and put "#" sign before lines:
ca ca.crt
tls-auth Wdc.key 13. add key-direction 1 at the end of file
4. paste at end of file
<ca>
---- content of ca.crt
</ca>
<tls-auth>
---- content of wdc.key
</tls-auth>
- Netduma_AlexNetDuma Partner
I can see from their support site that these are the OpenVPN files you want: https://ivacy.s3.amazonaws.com/support/OpenVPN-Configs.rar
- aeroluis88Aspirant
Hi,
I already download .ovpn files setup my username and password but connection states failed.
I had no issues with Vyprvpn, but I can't find the way for ivacy.
- Netduma-FraserNetDuma PartnerYou need to combine the .crt file with the .ovpn file for the server you want to use. The .ovpn will be at the top and then under that type <ca> then paste the .crt file and after that type </ca> so it should look something like this:
client
dev tun
etc
etc
etc
<ca>
contents of .crt file
</ca>
Then paste that into the advanced section on Hybrid VPN and enter your user/pass and it should allow you to connect.
- z0nkStar
ca ca.crt
<ca>
</ca>
<tls-auth>
</tls-auth>
- Netduma-FraserNetDuma PartnerHave you tried z0nks suggestion above?
