PolikosFoinix's avatar
Jan 26, 2019
XR500 Lan Ports - Fatal Flaw
     Ok.  So I have been at this since I bought my first XR500 from Amazon on March 28, 2018.  For the first few months everything was great, didn't even have to blink at the router much less reboot it daily.  That is not so much the case now.  I have now gone through 2 RMAs with Netgear to try and get this issue resolved because my router is supposed to be this thing that just works, not makes me work for it.
     I have lodged numerous support tickets to try and get this solved and have gone through the following between support requests and others (many others) who are having the exact same problem I am:
  • Beta Firmware
  • Current Firmware
  • Step back a version of Firmware
  • Disable DHCP and Assign Static IPs to my devices (A default function of the router, this is not an answer to the problem, it's a bypass.)
  • Disable Instant-On on my XBox (Again, a bypass for the bigger problem.  I shouldn't have to change a default function of another device I own to make my router work the way it's supposed to.)
  • Run Diagnostics in the background to forward and see why the hardware is failing
  • Removing devices from my network that on my R7000 worked without any problems together that are now supposedly a problem on my XR500.
  • I've tried checking the Disable Port Scan and DoS Protection in the WAN Setup due to the overwhelming amount of incorrectly identified DOS Attack log entries from Microsoft, Google, Blizzard, Steam; all perfectly valid communications.
     Yesterday I received my 3rd XR500, (Purchased from Amazon, RMA Replacement, RMA Replacement) and wouldn't you know it, I woke up this morning to disabled LAN Ports.  Shocking.  At this point I am truely at a loss for words.  I installed the newest router, updated the firmware (current version is 2.3.2.40) and still, the same problem.  I have loved my Netgear products since the first one I bought, but this one has disheartened me severely.
     I don't know if this is a flaw with the DUMA OS or with the hardware within the XR500.  I am truely at the end of my rope here.  If there is a way to do an RMA replacement for a different router I would take it at this point.  I'd even pay the difference to upgrade to an XR700 and hope that doesn't have the same problem.  If anyone has anything that they have figured out to add to this that I haven't figured out, tried or done to get this to go away, I'm open to suggestions.
  • Sorry to hear that, it is being invesigated and you've tried I think all of the potential workarounds/solutions so there may not be much I can do. Do you have any devices that use a standby mode or that use automatic updates?
    • PolikosFoinix's avatar
      PolikosFoinix
      Star
      Devices that I have in my network environment:
      • XBox One
      • Gaming PC (Win 10)
      • Asus Android Tablet
      • Samsung Android Tablet
      • Galaxy S8
      • iPhone 8
      I have disabled Sleep mode on both PCs to avoid network shutdown.  Both PCs are on Windows automatic updates, but that can't be disabled.  Aside from that, nothing else has a sleep mode capability.
    • billmarch's avatar
      billmarch
      Windows 10 is great but the forced upgrades are ridiculous. As far as I can tell there is no known way to permanently disable the updates. If you disable the update service, there are scheduled tasks that run regularly to re-enable them. If you cancel the scheduled tasks, as soon as you reboot your computer they get added back. The possible solution is that there should be a registry key you can set to alert you that windows 10 updates are available instead of automatically installing them.
      • FURRYe38's avatar
        Something you'll have to discuss with MS.
        Good Luck with that.
  • How do i get this firmware the link says "denined access"
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      The link was removed - it was just about checking for a firmware, there isn't a new one to download currently.
      • sivola's avatar
        sivola
        Tutor
        Thanks so much for Netgear and DumaOS for providing such bad support lets see how many more years until and if this problem would be solved
