pedro802
Jul 17, 2019Aspirant
XR500 Lan ports problem
There is no problem with wifi, but sometimes I get disconnected when I connect ps4 with lan cable. and it will resume normal immediately.
There is no problem when I try to connect internet without router.
Have you tried installing this hotfix firmware for dropouts? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
- Netduma_AlexNetDuma Partner
- pedro802Aspirant
The hotfix firmware I linked you to is based on the same version, BUT it has a small fix which stops dropouts. Apart from that fix, it is the same as the version you've got.
