Lazydayz137
Jun 05, 2019Tutor
XR500 Losing WAN Connectivity via WiFi Multiple Times Daily
XR500 running the latest firmware, don't recall the version, but the one that enabled "hybrid vpn." I lose WAN, or internet connectivity to all WiFi connected devices multiple times a day. LAN connection still works. Usually it comes back up in 10-15 minutes, but believe it or not, there are WiFi only users that find this unacceptable. And as the purchaser of a pricey router, I also find this issue unacceptable. I've tried various settings within the firmware after reading numerous threads on the subject, to no avail. There also appears to be a firmware fix for this issue floating around, so if there is, a link would be awesome. Otherwise, any other suggestions, tips, or tricks would be much appreciated! Thanks so much!
-Lazydayz137
- Netduma_AlexNetDuma Partner
Here's the firmware hotfix you're referring to: XR500 Firmware Version 2.3.2.32
Hopefully that fixes the issue. If not, let us know.
Thanks! I was using a newer firmware version. Shame the fix didn't make it into that. But, knock on wood, I've been running the firmware you linked for a couple days and haven't experienced any disconnects. If we can get a few more days of uninterupted service, I'll mark this as an accepted answer. Just don't want to be too hasty, because as soon as I am, it will start dropping left and right. Thanks again Alex!
-Robert
- Netduma-FraserNetDuma PartnerGreat to hear that, keep us updated!
