Ra7cio's avatar
Ra7cio
[XR500 Netduma] problem with dhcp Ubiquiti LocoM2
After yesterday update firmware to XR500 V2.3.2.114-DumaOS3.0.203  i have a huge problem.
On list devices i cant see my Ubiquiti Loco M2 Access Point and Station. (bridge to other building).
But funny think - after update work fine. Today, after 15-16 hours i have trouble and now I try everythink.
Change firmware to .108, factory reset, hard reset etc. Nothing work. I reset my Loco M2 and when i plug in LAN cable to laptop it's work. When i plug to router - cant connect to Loco M2.
I have LAN setup on XR500: 192.168.0.1
On Loco M2: 192.168.0.20.
On list online/offline devices Loco m2 does not appear. I cant ping 192.168.0.20. I think its problem with DHCP? Or IP adress? Please help. Another devices with manualy IP config works.
  • If it is in Access Point mode then it should be transparent to the router so it won't really see it and any devices connected to the AP will appear as though they are directly connected to the Device Manager. Is the problem that you're just unable to access the AP interface rather than connection issues?
    • Ra7cio's avatar
      Ra7cio
      unfortunately Its connection problem, devices on another building have not connection to internet
      • Ra7cio's avatar
        Ra7cio
        I try reconnect Loco M2.
        Loco M2 station: 192.168.0.19
        Loco M2 ap: 192.168.0.20
        When i on lan cable work ok.
        When i switch lan cable to xr500 one of Loco M2 (station) in second (ap) have info about LAST IP ADRESS (station): unknown.
