Mrcurlyyyy's avatar
Mrcurlyyyy
Xr500 nighthawk not connecting to ps4
My nighthawk router works on everything including my phone, laptop, even my TV but when I try to get it on my ps4 it always says it can’t connect to the internet.. I tried restarting I tried everything and nothings working. I don’t know what to do, need serious help
  • plemans's avatar
    what modem/gateway is it connected to ?
    What firmware is on the router?
    did you go into the ps4 and forget the network and then retry?
    • Mrcurlyyyy's avatar
      Mrcurlyyyy
      I’m using a spectrum modem and router..
      I’m not entirely sure what you mean by gateway I’m not to big on this stuff. I did try disconnecting multiple times and I get the same result. And I have it plugged in via Ethernet cord so I’m just confused and don’t know how to fix it
      • plemans's avatar
        the spectrum modem/router is the gateway. What model is it?
        And not just disconnecting but erasing the settings for the wireless.
