aj_la1
Aug 21, 2019Aspirant
Xr500 Nighthawk wired laggy and slow internet
Need help, I have
Firmware version XR500 V2.3.2.56
My internet is not stable wired and wireless. Speeds with the modem is 111 download and 10 upload. Router does regonize this. But sadly when i use the bufferbloat to 70 I am not able to play any games online. Black ops 4 cant connect to a multiplayer match and apex lags and kicks me out of a game. Check with the internet company and its ok on their end. I contact support but they cant handle it so a specialist will be calling me in two days. Router has been working fine for over 2 years. Now, everything has gone wrong. I disable most thinks and still netflix gets buffered and cant play games. I need help guys. Also i seen fixes getting old firmware. Hope to hear from some one soon.
I just setup my XR450 with v56 today on a 200/10 ISP and speed testing is to spec, via wired PC and NG Nighthawk app on iPhone and Android pad.
- Netduma-FraserNetDuma PartnerSo to confirm you've disabled QoS & Geo-Filter fully and these issues still occur?
- aj_la1Aspirant
i did that and no dice. ill try again
- aj_la1Aspirant
Model number is xr500.
I just yesterday made a factory reset and things havent improve. Before the factory reset it had the latest firmware and still the same thing.
speeds on my modem are 111 download and 11 upload.
I try updating it back to the latest firmware again a see what happens.
What is the Mfr and model# of the ISP modem the XR router is connected too?
- aj_la1Aspirant
modem is arris and model is tm1602A
dont know what mfr
- Netduma_AlexNetDuma Partner
Are you using a computer? Could you download PingPlotter and show us a screenshot of your results?
Here's a guide: https://forum.netduma.com/topic/23881-ping-plotter-quick-guide/
