quadrophenic
Jul 05, 2018Apprentice
XR500 noip not working
For an unknown reason my XR500 has decided to not login into NO-IP anymore. I have a mynetgear account and when i try to enter the details in the config it loads then blanks out all of the fields.
- Jul 09, 2018Check on the NO-IP site that your host name hasn't expired. Also try choosing no ip from the drop down provider list instead of Netgear and see if that works.
Netduma-Fraser
Jul 09, 2018NetDuma Partner
- quadrophenicJul 10, 2018Apprentice
Selecting No-ip from the drop down solves the problem. Thanks.
