quadrophenic's avatar
quadrophenic
Apprentice
Jul 05, 2018
XR500 noip not working
For an unknown reason my XR500 has decided to not login into NO-IP anymore. I have a mynetgear account and when i try to enter the details in the config it loads then blanks out all of the fields.  ...
  • Netduma-Fraser's avatar
    Jul 09, 2018
    Check on the NO-IP site that your host name hasn't expired. Also try choosing no ip from the drop down provider list instead of Netgear and see if that works.
