Nikkimacv's avatar
Nikkimacv
XR500 not broadcasting SSID
So I setup my router for the first time today, and when I was trying to connect to it, I couldn't fine the SSID in the available in the Available Networks. The name that I do believe is my router doesn't accept any password it possibly could be, and isn't the standard SSID on the bottom of the device.
  • OK, it sounds as though you'd be best to factory reset the XR and set it up from scratch.
    Could you please hold the reset pin on the back for at least thirty seconds, then allow it a few minutes to reset itself. After that, everything will be set back to it's default and you can then complete the setup wizard.
  • Hey,
    Could you connect to your XR500 directly via ethernet, then go to 192.168.1.1 in your web browser.
    If you then go to Settings -> Setup -> Wireless Setup you can view the wireless SSID and password here.
    • Nikkimacv's avatar
      Nikkimacv
      Well, I just tried that, and said the admin password was wrong so it requested the serial number so I could reset the password, entered that and now it is
      asking for answers to security questions that I never even setup before.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
