Ewim89
Sep 12, 2020Follower
XR500 not connecting to wifi
Hi I’ve reset my router and it is not connecting to my WiFi.
- Ego556Aspirant
it's not connecting to your wi-fi? are you using it as something other than a router or did you mean it's not broadcasting wi-fi? is the wi-fi button on? what dumaos version?
- Netduma-FraserNetDuma PartnerAfter you reset it did you re-enter the default password for the WiFi on your device? It will have reverted to the password located on the sticker on top of the router.
