Cholete's avatar
Cholete
XR500 not searching lobbies in cold war
So from one moment to another the router started to not search lobbies, i have reset the router and still happens the same! Any solution? Thank you
  • it only happens in cold war! Ping heatmap not showing any server and every other game listed shows servers... Solution?
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Are you referring to Ping Heatmap, the Geo-Filter or both? We're aware that Ping Heatmap is failing to ping servers and we'll be pushing a cloud update to fix that so should be done within the next two days.
  • FURRYe38's avatar
    Are you able to join game lobbies with others as well or not?
