jordy787
Mar 31, 2019Guide
xr500 not showing moca 2.0 devices
I have a xr500 and Just setup moca 2.0. I am using a linksys lgs105 unmanaged switch so I can connect my xbox and pc through moca.. anyways they dont appear to be displaying under devices on the router so I am unable to setup QoS and bufferbloat., any ideas?
I got it to work, I did not know I have to plug the moca ethernet into a specific port (port 5) on my unmanaged switch. All devices are showing after doing that. Sorry about that
Do they show up if directly conneced via LAN cable to the XR router?
- jordy787Guide
Yes, they do. I did notice they show up now but its under offline, my pc doesnt show a ip under device manager but my xbox does(router page). Do I need a managed switch for it to properly display and to configure with QoS?
That would be a subject for Netduma_Jack Netduma-Fraser Netduma_Luke - technically the MoCa 2.0 is just yet another Ethernet bridge, the MAC addresses become visible to the router either already from the DHCP process, or at least once the router resp. the Internet is accessed. If they have access but don't show up - I would name this Voodoo.
No, a managed switch does unlikely help to make the devices visible. But here again, it would be interesting to hear what the Netduma geeks state about multiple devices connected over a switch to the DumaOS router.
