DankPro's avatar
DankPro
Tutor
Nov 29, 2022
XR500 only has usb2 light soild
Okay so I have a xr500 night hawk router that when powered on no other light come on but the usb2. The led switch on the back is on. Now if I plug in my cable from the back of my computer to port 1 on the router the led on the front blinks like it is receiving and sending. Upon going deeper in to the setting on my pc under network connections right click and details my computer is sending packets but not receiving. I have downloaded the earliest firmware and tried flashing it with tftp on command and using the tftpd64 utility with no luck i also tried using factory ddet firmware nothing. i also tried nmrpflash. is this router just dead?
  • FURRYe38's avatar
    What happens if you disconnect everything from the router and press the reset button for a full 10 seconds then release.
    The POWER LED should be on soon after the reset beings.
    Check the volts and amps at the tip plug in to be sure that the volts and amps seen are what is on the power adapters sticker.
    Have you access the routers web page at 192.168.1.1 after the reset happens after about a minute?
    • DankPro's avatar
      DankPro
      Tutor
      The power adapter is the oem 12v 3.5amp. Now with nothing connected to it then a power cycle with only the power hooked up all the leds on the right half light up then go off and im stuck with only the usb2 led on solid. the reset button seems to do nothing when pressed for 10sec.
  • Are you actually receiving internet through devices connected via ethernet or WiFi?
