Tigsman
Jan 29, 2020Tutor
XR500 port assignments backwards?
so looking in the DumaOS(.56) device manager (list view is simpler) I recently noticed that port 1 is currently 100mb, the other 3 1000mb. However, on the router itself, its not port 1, but Eth 4 light that is orange. Based upon dhcp assignment it appears the OS sees the port numbers backwards. Anyone else seen this?
T
- Okay in that case it might be something we need to look into ourselves. If it is an issue for you downgrade and check if it reports correctly.
- Netduma-FraserNetDuma PartnerDid you notice this on previous versions of the firmware? If not then it's an aesthetic bug we'll need to fix. If you did then did you buy the router very early on when it was announced? If so there were a batch of routers that had this incorrect assignments just affecting the aesthetics and not performance.
- TigsmanTutor
i know that eth4 is the 100mb connection (direct connection to Phillips Hue hub), has been since i got it. I just recently noticed the port assignments in the DumaOS, not sure how long it has been that way. port 4 in back of router and eth4 light in front seem to correspond correctly. DumaOS seems them backwards. As for when i got it, my 1 yr service agreement expired a short time ago 1-3 months.
Netduma-Fraser wrote:
Did you notice this on previous versions of the firmware? If not then it's an aesthetic bug we'll need to fix. If you did then did you buy the router very early on when it was announced? If so there were a batch of routers that had this incorrect assignments just affecting the aesthetics and not performance.- Netduma-FraserNetDuma PartnerOkay in that case it might be something we need to look into ourselves. If it is an issue for you downgrade and check if it reports correctly.
