ThinkMcFlyThink
Sep 27, 2018Star
XR500 router rebooting every 5-10 minutes when USB drive plugged-in
Recently I made this post in this forum about a brand-new XR500 rebooting every 5-10 minutes. This occurred with a first XR500 router that I returned and replaced, and then again with the replacement router which I'm still using today. After doing a factory reset, everything appeared to be functioning normally.
Yesterday when I went to listen to some of my music I noticed that I had not plugged my external USB drive back into the router after doing the factory reset. I plugged my USB drive (Toshiba Canvio 500GB; model HDTC605XK3A1) into the router and lo-and-behold the rebooting issue returned. This occurred in either USB slot.
Anyone seen or experience something similar? Keep in mind this issue has happened on two units, not just one, though I thought the first unit was faulty for different reasons at the time.
Firmware version: V2.3.2.32
- Netduma-FraserNetDuma PartnerThat's very interesting. Is the router utilising the USB device for any purpose when you notice this happening or can it be idle and happen?
The USB LED light is on, and the SSD light on the enclosure is lit-up blue.
- Netduma-FraserNetDuma PartnerInteresting okay, as its to do with hardware I'd recommend you contact the Netgear support line and they'll be better able to help you with that issue.
- Havix00Aspirant
This same thing happens to me when I plug my external SSD into the XR500 router. After I access its network folder, the router reboots. I think it has something to do with the power fluctuation, or the router CPU overload. I'm not sure how to fix this as I also have a power adapter connected to the external's enclosure. Just my thoughts.
Please update if you've found a solution.
- Netduma_JackNetDuma Partner
Ok, thanks for letting us know. I'm not sure if this is addressed in the next firmware, which should be released soon, as it's on the NETGEAR settings side. But I'd recommend waiting for this firmware and trying again. If the issue is still there, post on the forum and we can elevate it to the devs at NETGEAR for you :smileyhappy:
No update from me either, same issue persists. Will attempt with the next firmware update.
