flekballs21
Jan 25, 2020Aspirant
Xr500 setup to opt
Hi I’m trying to set up my nighthawk xr500,
I wanted to know if I can set it up and how directly running from the OPT. I have NZ fibre100 and I seem to only be able to run it from OPT to modem to xr500 router. I am currently unable to play rainbow6 on ps4 while someone is watching Netflix just constant rubber banding.
Any help would be great thanks
- Netduma-FraserNetDuma PartnerAre you able to connect the ONT via ethernet to the XR500? You may have to get an adapter to do this. Also you may be required to enter PPPoE or VLAN settings on the router before you can directly connect the two and receive internet. Regarding the lag I would recommend you follow our optimal settings guides, particularly the QoS guide in order to resolve this: http://support.netduma.com/en/support/solutions/folders/16000090646
- flekballs21AspirantSo I’ve just moved address so will be trying to set up and sort this coming week. I’ll receive my internet providers modem tomorrow. There is an Ethernet port on the ONT that says internet and I can plug this in directly to the XR500’s internet port via Ethernet cable.
In regards to VLAN and PPPoE, I don’t actually know how to set this up. Will I need my Internet providers modem before I can set this up and where do I start?- Netduma_AlexNetDuma Partner
I imagine you will need your internet provider's modem before you can do anything, especially if you're moving to a different provider.
They'll also need to set up the connection from their end. But in theory you just connect the ethernet port on the modem to the yellow WAN port on the back of the XR500 and perhaps do a factory reset to get it started.
