arnolyuna
Jan 20, 2023Follower
XR500 Speed question
What is the max speed (wired) XR500 can handled? My speeds from ISP is supposed to be 1200Mbps-D 45-U. I know the Xr500 says it has 4 - 1 Gigabit ports. When I run speed test I'm getting 944 Down, ...
Jan 20, 2023Guru - Experienced User
Max speed you'll never see on the XR500 is around or just over 900Mpbs since the WAN AND LAN ports are 1000Mpbs only.
arnolyuna wrote:
What is the max speed (wired) XR500 can handled? My speeds from ISP is supposed to be 1200Mbps-D 45-U. I know the Xr500 says it has 4 - 1 Gigabit ports. When I run speed test I'm getting 944 Down, is that normal for 1 Gig port, or should it max out at 1000D?
