djgraff209
Jan 30, 2020Aspirant
XR500 Static Route dropping packets
I'm running into an issue with my XR500 router. I'm running the lastest stable firmware (check from router indicates latest version).
I have a virtualization server that I'm hosting a Linux bridged network on. I have configured a static route in the router to route 172.16.0.0/12 to a fixed address 192.168.1.26 on my network.
What I'm seeing is intermittent TCP retransmissions while conntected to a VM on the bridged network. There does not seem to be rhyme or reason for when the packet drops start occurring.
I have monitored from the client machine using wireshark and from the virtualization host using tcpdump. When the retransmissions start (as seen from the client) I do not see them reaching the virtualization host interface.
I disabled the static route on the router and manually entered the route on my laptop. Monitoring again, I am seeing no retransmissions.
My only thought is that the router is for some reason (randomly) dropping packets. I don't know if this is QoS related or not and have tried to disable QoS and geo-filtering with no impact while on the static route on the router.
Any help would be appreciated.
- Netduma-FraserNetDuma PartnerIt could be QoS related - how did you disable it? It should be disabled from the Anti-Bufferbloat 3 line menu to make sure. How do you have your router setup as well?
- djgraff209Aspirant
I went into the administrative screens, under QoS set anti-buffer bloat to Never, turned off traffic prioritization.
There are no geo-filter devices set.
My network is a little more complex than most.
I have disabled DHCP on the router. I have a linux server hosted on 192.168.1.2 configured to serve DHCP & DNS functions.
Network is configured as 192.168.1.0/24.
I have a linux virtualization server hosted at 192.168.1.26 (static IP). Underneath that server I have a linux bridge configured to host a virtualized set of networks (currently 1) in the 172.16.0.0/12 range. The hosted virtual network is 172.16.1.0/24. I have configured routing and masquerading and am able to successfully reach hosts on that network as well as have them reach the internet and local lan.
- Netduma_AlexNetDuma Partner
Try completely disabling QoS. On the anti-bufferbloat panel, there's a side menu which contains a full Disable for QoS. This will allow us to narrow down the problem.
