Deijeneiro's avatar
Jun 03, 2021
XR500 to XR1000
Hi guys ,
Todat I want to upgrade. Currently on the XR500. My question is the DUMA OS 3.0 better the the xr500 beta version. Because because of the many bugs I’m currently not satisfied with the XR500.
  • It is more polished on the XR1000 yes, it's still a very new router though so there will be some bugs of course, nothing is perfect but we'll get those sorted. Has the .120 beta version on the XR500 not worked well for you?
    • Deijeneiro's avatar
      Deijeneiro
      Guide
      Did not work well for me idd.
      Now next problem I bought the XR1000, fresh out of the box...
      DumaOS not loaded yet!
      Don't worry we will redirect you shortly.
      Did everything already!? its not like a few bucks or something!????
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What web browser/device are you using to access the interface? Is the router plugged directly into a wall outlet or an extender?
