Anonymous's avatar
Anonymous
Jun 11, 2022
XR500 USB Printer Support
Hi guys,
I am trying to connect my Samsung SCX-3200 Printer to my router however it is not detected on the routers web page, nor can I see it using the USB software from Netgear. I see the USB LED flash on the front when I connect it initally however nothing happens after. I have checked the cable works and also the port works (USB Memory Stick) however the printer does not.
Has anyone successfully used this? I am using the latest firmware (132).
Many Thanks,
Chris
