geomoondog
Apr 17, 2021Aspirant
XR500 V2.3.2.114 causes Media Server issue
Netgear XR500 Firmware update XR500 V2.3.2.114 and up: Once I install updates I can not play any videos anymore from Infuse 6 on my AppleTV. When I install the V2.3.2.56 it runs fine! Does anyone know why that is? I have spend hours troubleshooting this problem.
- Netduma-FraserNetDuma PartnerDid you factory reset after doing the upgrade? If you disable QoS fully does it work?
- geomoondogAspirant
Yes I have tried the factory reset and my Qos is disabled but no luck. I have downgraded back to version V2.3.2.56 and it all works fine now. Later on I will buy another router, not a Netgear and I hope not to have these kind of issues again.
- Netduma-FraserNetDuma PartnerYou could try the DumaOS 3.0 beta and see if it works as that will be the firmware we will be using going forward
