mallibr's avatar
mallibr
XR500 V2.3.2.56 Hybrid vpn to purevpn is not working
I am trying to Negear XR500 (Router firmware latest version XR500 V2.3.2.56) Gaming router with Purevpn using Hybrid vpn client and it is not working. It is throwing certificate and TLS issues below.
Sat Jun 27 20:33:48 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:33:50 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:33:54 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:34:02 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:34:18 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:34:48 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Jun 27 20:34:48 2020 TLS Error: TLS handshake failed
Sat Jun 27 20:34:48 2020 SIGUSR1[soft,tls-error] received, process restarting
Sat Jun 27 20:39:48 2020 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Jun 27 20:39:48 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sat Jun 27 20:39:48 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]172.94.108.4:53
Sat Jun 27 20:39:48 2020 UDP link local: (not bound)
Sat Jun 27 20:39:48 2020 UDP link remote: [AF_INET]172.94.108.4:53
Sat Jun 27 20:39:48 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.94.108.4:53
Sat Jun 27 20:39:50 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.94.108.4:53
Sat Jun 27 20:39:54 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.94.108.4:53
Sat Jun 27 20:40:02 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.94.108.4:53
Sat Jun 27 20:40:18 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.94.108.4:53
Sat Jun 27 20:40:48 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Jun 27 20:40:48 2020 TLS Error: TLS handshake failed
Sat Jun 27 20:40:48 2020 SIGUSR1[soft,tls-error] received, process restarting
Sat Jun 27 20:45:48 2020 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Jun 27 20:45:48 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sat Jun 27 20:45:48 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]45.74.52.4:53
Sat Jun 27 20:45:48 2020 UDP link local: (not bound)
Sat Jun 27 20:45:48 2020 UDP link remote: [AF_INET]45.74.52.4:53
Sat Jun 27 20:45:48 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]45.74.52.4:53
Sat Jun 27 20:45:51 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]45.74.52.4:53
Sat Jun 27 20:45:55 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]45.74.52.4:53
Sat Jun 27 20:46:03 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]45.74.52.4:53
Sat Jun 27 20:46:19 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]45.74.52.4:53
Sat Jun 27 20:46:48 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Jun 27 20:46:48 2020 TLS Error: TLS handshake failed
Sat Jun 27 20:46:48 2020 SIGUSR1[soft,tls-error] received, process restarting
Sat Jun 27 20:51:48 2020 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Jun 27 20:51:48 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sat Jun 27 20:51:49 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]141.101.166.4:53
Sat Jun 27 20:51:49 2020 UDP link local: (not bound)
Sat Jun 27 20:51:49 2020 UDP link remote: [AF_INET]141.101.166.4:53
Sat Jun 27 20:52:49 2020 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sat Jun 27 20:52:49 2020 TLS Error: TLS handshake failed
Sat Jun 27 20:52:49 2020 SIGUSR1[soft,tls-error] received, process restarting
Sat Jun 27 20:57:49 2020 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Jun 27 20:57:49 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sat Jun 27 20:57:49 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]172.111.147.4:53
Sat Jun 27 20:57:49 2020 UDP link local: (not bound)
Sat Jun 27 20:57:49 2020 UDP link remote: [AF_INET]172.111.147.4:53
Sat Jun 27 20:57:49 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
Sat Jun 27 20:57:51 2020 TLS Error: client->client or server->server connection attempted from [AF_INET]172.111.147.4:53
    • mallibr's avatar
      mallibr
      Yes, it is the same issue on both TCP and UDP. I also tried with several different server locations but no luck. It just hungs at connecting. I was thinking that multiple reboots may fix the problem, unfotunately not though.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you try downloading a PureVPN config from their website and using it with the advanced section please and see if it allows you to connect? Might be that we need to update the configs we have on file.
